anybody got an alternator bracket laying around?
chowitworkz
Yeah I'm sure I do, although someone closer to you may have one also. Let me know if you want one of mine.
TwoTone IDI
ZF swap completed!
Richmond, VA
im sort of in a bind so the proximity doesnt make much difference to me... if you can find it lemmie know and ill put some jingle in your pocket
just to be clear im looking for the semicircular bracket with a slot in one end to adjust tension, and two bolt holes in the bottom that attach to the water pump housing.
TwoTone IDI
ZF swap completed!
Richmond, VA
i dont really know what theyre worth. id like to see a picture of it before anybody ships just to be sure im not buying a paperweight.
dyoung14
Is getting worn out
spencer,tn
i have no way of posting a pic today, maybe tommarrow if im reminded, but i promise there nothing wrong woth them, i wont sell nothing unless its good
TwoTone IDI
ZF swap completed!
Richmond, VA
sorry, i am a v-belt.
dyoung, not saying you would sell me junk, i just want to make sure im getting the right thing... for reasons like towcat mentioned above :D
if youre also running a v-belt i should think the parts are interchangeable, even between 6.9s and 7.3s.
dyoung14
Is getting worn out
spencer,tn
mine is V-BELT if you can post a pic of what you got then we can know for sure what you want and i know i have what you need i got 4 junk engines now
"the warden" has this little item in his posession. He can overnite it to you tomorrow.
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
What he said. However, after reading this post, I think TwoTone's looking for the other part (i.e. the one you held onto) :(
TwoTone IDI
ZF swap completed!
Richmond, VA
yes im looking for the black crescent shaped tensioner portion. you can see part of it in the second picture.
dyoung if you think you can get that to me i would be much obliged.
Cv axle
