another smoke video
Slicknik
Burbank, CA
@eldomike
What is your question?
What color is the smoke ? (Hard to tell in the video )
Does the smoke go away after the truck is warmed up?
catbird7
PA
Only thing I see that's concerning is the air intrusion. To me the engine sounds healthy and the smoke appears normal for start up especially if it's cold. Electric pumps usually work best when they push fuel and with the pump located near the selector valve bad fittings and cracked fuel lines will quickly show up as a fuel leak. Much easier to locate a fuel leak as compared to an air leak.
