soggybottom
My truck has always started hard when cold (below freezing). It takes 2 to 3 cycles of the plugs if it starts at all. Plugged in for a couple hours it pops off as fast as I can turn the key.
I have all new glow plugs, and have verified that they work. The truck turns over very fast. I have great compression. The truck has new return lines/orings/olives and an electric fuel pump. I am getting fuel, because when the truck is cranking I get a lot of white smoke. I am running out of things to replace.
My pump and injectors appear to be original with 230k miles on them. Is my truck going to start better with new injectors/pump, or should I drive it to the bottom of a lake?
Thanks. Really appreciate the help on this site.
