69dieselfreak
well that nice
got to say that is an interesting combo i like it thats good u didnt go with a cummins dare to be different
Are you going to do the torque converter lockup mod? If you do you cam just leave the converter locked when decelerating and when going downhill, tis supposed to work real good, so maybe no exhaust brake necessary?
Looking good. With an electric vac pump you would have room for onboard air.Good luck Doug!
I keep hearing the exhaust brake is a killer on these engines as well. Towcat had some reasons for that...don't rightly recall at this point, but as you said it has to do with the valve train.
Looks great! I had no idea you'd have to cut the floor out though.
Our motors have 100lb valve springs. with the exhaust brake, It won't take much effort to open the valves from the backpressure. There is brakes out there that have a overpressure valve that minimizes that from happening, but the risk is still there.I keep hearing the exhaust brake is a killer on these engines as well. Towcat had some reasons for that...don't rightly recall at this point, but as you said it has to do with the valve train.
that pretty much sums it up.So, the valves open, pistons come up and "That'll be $3000, thankyouverymuch". Sound about right?
