And pictures....
First we'll start with the teardown.... This is the reason for the whole evolution - had a weird rattle noise that sounded like valve train, or stuck injector but after both were ruled out it was concluded that it was something more serious, likely a loose wrist pin. As it turns out that was wrong. Apparently when it overheated as a result of a small coolant leak from the block heater it caused more damage than I'd thought at the time and somehow a small chunk of one piston welded itself to the cylinder at tdc and was ripped off the piston. The noise then was the piston bashing into this bit.
![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Surprisingly it seemed otherwise fine for 20-30k miles running this way.
