Thefarmboy21
I just dropped the front tank on my 87 and fixed the showerhead issue, haven't got to the rear YET. Anyway I have the water separator bypassed for now and have a clear fuel filter in it's place. The truck idles fine and drives fine (smokes a little white/grey and lacks power) but while watching the clear filter at the fire wall I can see small air bubbles coming from the tank side. The filter just ever so slowly is filling with less fuel and more air. The air bubbles are probabl only the size of some #5 or #6 birdshot pellets and only comes about every 2 seconds at idle.
Is there anyway to test it to track down where the air is getting in? I haven't noticed any leaks while shut down. My truck has the quick fittings (push lock) at the tank and both sides of the FSV. Also is there a way to test the FSV? Currently I am NOT using the rear tank.
