Air Filter Modification and battery light
Lockedhearts
I plan to modifiy the air filter to the BHAF , doing some searches, I found that most, remove the orgional filter holder, adapt the BHAF and just set it in place. Opinions? Also, I drove almost 200 miles round trip yesterday to pick up a load of hay. This morning my battery light was on and stayed on for a bit , battery gage showed charging. Thinking I need to keep a close eye on my alternator?
deff keep an eye on the ALT.
my stock box is gone, with a K&N hanging where the box used to be
Lockedhearts
I saw a mod using a piece of pvc pipe to connect the filter to existing hose, is there a better way? I assume the pvc way is less expensive.
94f450sd
somewhere,ma
Search diy tymar type intake.this setup was extensively tested and proven to flow more and filter better than any other filter kit on the market.itll cost about 100 bux for everything needed.
On the alternator there is a tiny plug with a single wire.unplug it and see if its dirty,corroded or loose.if loose bend the metal connector inside the plug so it makes a good tight connection.this is usualy the reason for the battery light coming on even though the gauge says its charging.
ACDELCO A1474C
AIR REFINER ARM08-5011
BALDWIN FILTERS PA2818
BIG A 94637
CATERPILLAR 3I0003
CARQUEST 88637
CUMMINS 2912986
CUMMINS 3912020
DONALDSON B085011 H
DONALDSON ECBO85011 H
DONALDSON ECB085011 H
FLEETGUARD AH1141
FLEETRITE AHR81141
FRAM CA6818
GFF AF359214
GENERAL MOTORS CORP. 25177209
HASTINGS PREMIUM FILTERS AF2329
HERCULES B085008
KRALINATOR LA1458
LUBER-FINER LAF2533
Napa 66637
Wix 46637
Or drop by here http://www.riffraffdiesel.com/riffraff-diesel-6637-filter-kit/
Lockedhearts
Thanks! I plan to do this over the weekend, and yes my alternator croaked, got it replaced, waiting for the next issue to crop up. Hoping I can find and easily fix the vaccuum leak on our 98 explorer before something else happens :rolleyes:
Grizzly Wrecker
