Additional Fuel Filter
BRONCO
Would these things help my oil from being black and stinky at only 3-5 k ?
Max Power
Depends on if you use new toilet paper or used. :D
Whit
lost in Why-homing
Hell 3 - 5 k aint bad, with all the fuel I am adding I can blacken the oil at 1k I want it outa there.
hheynow
the misanthrope
SF Bay Area
It will help keep your oil clean for many more miles than that. Some use synthetic oil with a bypass setup and only change their oil when the lab results indicate to do so. That means extended drain intervals of up to 10K and more. However if you have traces of oil in your fuel...it won't help.
Stinky? ALWAYS! :D
Whit
lost in Why-homing
I run Cummins premium blue synthetic and have never had a problem with fuel in the oil, by the way the 2 micron filter is a $20 buck spin on from Amsoil and it does do a good job on everything but the soot
hheynow
the misanthrope
SF Bay Area
As I'm only familair with the Powerstrokes, oil in fuel can mean an o-ring problem. Personally, I avoid Amsoil products. IMO they are over priced. My Oil Guard replacement filters are $13.00 each and rated at 1 micron filtration.
Whit
lost in Why-homing
Hell, I outa see if an Oilgaurd will spin onto my housing........thats a great price! Where do ya get them?
hheynow
the misanthrope
SF Bay Area
I would really like to add a soot filter between them but am seeking advice from someone that has been there and done that, can you add to that ?
Whitmore, As far as soot...nope. Personally, I think filtering below 1 micron is overkill as evidenced by my periodic Blackstone Labs reports. Besides being a thorn in your side, what adverse effects does soot have? Is the cost of a soot filter really worth its benefit?
I'm as **** with my truck as you seem to be with yours :Thumbs Up. If I truly believed that adding it would benefit my truck...I would have done so by now. Geez, I have an oil bypass filter, a coolant bypass filter & a magnetic inline tranny filter right now and have to keep records of each's last change...so I can sleep at night :confused:.
P.S. But your spark plugs are FATTER! ;)
P.P.S.You can get them Here, but the housing is not cheap and no, it won't fit onto your setup.
Whit
lost in Why-homing
Right on bro, I hear ya on being **** with maintenance LOL
So what effects do soot have in the oil anyhow, I dont know. I have never analized my oil, tried to with Blackstone and they lost the results so I went with a different company and the same **** :mad: , so now I have 6 kits paid for in the garage and have never used them, Guess I should
Cheers, Kevin
Got Juice?
Stack Daddy
i see GM has now approved the racor pre oem for 'severe service' applications... see your dealer, they all got the info
rubberfish
Langley B.C.
Larry, :confused: whats his posting name?
Profile For lschultz Search for all posts by this user.
Date Registered: 12-21-2003
Status: Senior Member
Total Posts: 302 (3.03 posts per day)
Last Post: 03-29-2004 07:05 PM
Insanity TEST
Contact lschultz: Click here to email lschultz
Send lschultz a Private Message!
Homepage:
ICQ Number:
AOL Instant Messenger Handle:
Yahoo Instant Messenger Handle:
Birthday May 20, 1948
Custom Title
Biography Retired but still working
Location Cistern,Tx-2.3 miles outs of ofs highway
Interests
Occupation Utility Plant Operator
REM70
