jaluhn83
What's involved in converting the earlier D44HD w/o ABS to have the front ABS sensor used on the 92+ rigs? Is the sensor mount machined into the knuckle or is it a separate piece? Tone ring looks like it's part of the hub, so that should be simple, just swap hubs. Any differences in bearings, spindle, etc?
Right now I'm running my speedo and cruise control off the ring gear sensor on the 10.25 rear. I am planning to swap that out for a D70 rear which will then leave me without a speed signal and I have been trying to figure out the best approach to add another signal source. It occurred to me this afternoon that putting a front ABS sensor on one of the front wheels might be a good solution is it can be done without too much headache. I think it is likely that the output signal form will be similar so it should be compatible although the front tone ring looks like it has about 1/3 the teeth which might be an issue for the cruise.
Thanks,
~John
Thanks,
~John
