This is what a York looks like:
What you have is the Ford I believe made by Visteon A/C compressor they started using in the very early 80's and still use a variant of it to this day. My 03 Excursion and 00 P71 have this same style:
The York is a piston type pump, just like your engine, there is an oil sump, a crank, connecting rod, piston and head. Instead of it running like an engine, it is driven and compresses with the same idea. Many have used a York A/C compressor for on-board air. There is a bit of modification most make, but it will compress air same as freon.
The Ford pumps is a rotary vein type pump. It is lubricated by the "oil" in the refrigerant. These can not easily be made to be on-board air, since you have to have the oil in the gas going through them, meaning your compressed air, would be full of oil, and need to be constantly replenished. Being a vein type pump, on a quieter engine (such as a gasser, our F-150 and E-150 both had this pump) you can hear the pump whine a bit while it is running.
