My Green machine needs an the AC serviced as i have no AC , Compressor clutch engage and tested fine , It's currently running the old System R12 . I am going to Pull Vacuum this weekend and service it to make sure no leaks . I have access to R12 my questions are :
1- Should i convert the system to R134 or Leave it alone ( As i did read some where that the older condenser might not handle it well )
2- The green machine is CC so it's a large area to cool . What orfus tube should i stick with ( the colored one or variable )
3- where is the orfus tube located
Thanks
Thanks
