Ac compressor advice
subway
be nice to the admin :D
York PA
Since I did my engine swap I need a v belt compressor. I was hoping I could swap the pulley on my compressor since I bought it new a couple of years ago and it seems to work well.
Does anyone know of a front pulley I could swap on or if the other older compressor I have would be sufficient. I know they made improvements over the years. The older compressor came on my 88 dt360 but I have no idea the history, it does seem to turn over smoothly.
Thanks.
typ4
Newberg,OR
I have a ford fs6 v belt clutch assy. New.
subway
York PA
Would that fit my newer compressor?
typ4
Newberg,OR
Which one in the pic do you want it on, should fit the black one
typ4
Newberg,OR
I know, should be a 10 by quick glance. That's why I was asking.
subway
York PA
I would prefer to run the compressor on the right that currently has a serp pulley on it. I need to convert to v belts for my dt360 engine though.
The compressor on the left has the v belts but I have no idea if it will work well with 134 and I don't know the history of it.
How can I tell what it is? Would more pictures or numbers help?
needlenose
Irrelevant Data
I wanted to do the same when I did the 12v swap since the v-belt is thinner than the serp and I was concerned about spacing. The compressor shop I went to said it wouldn't work. Something about the compressors are different enough that the v-belt pulley wont work. I ended up taking an old FS10 pulley and cutting the center out of it on the lathe. Turned and drilled a new center plate and welded it all up. It's bolted up to the front of the fan pulley. Now I can just buy all stock parts with no mixing and matching.
subway
York PA
That's a good idea but I don't think I have the room for that lol maybe I could do some variation on that idea.
Greg5OH
MI
cant help ya but 2 belts on the w.p. me likey.
typ4
Newberg,OR
Use the belt comp, drain the oil and use oil for 134. Compressor doesn't care what it pumps.
needlenose
Irrelevant Data
Um, yeah, you're a bit real estate challenged there. :)
Is that pulley super rare? If not, just turn down the two outer grooves until you can press a hollowed out FS10 serp pulley onto it, then weld in place. I trimmed 2 grooves off my pulley since the IDI only used a 6-rib anyway. It works great.
If it's hard to get, I wouldn't mess it up.
subway
York PA
Ha! Maybe I should just run an inverter and a window unit out the back. I can even be dazzle the sides so it does not look all red neck like!
That is an idea to turn down the water pump pulley to fit a serp belt.....
typ4
Newberg,OR
The belt compressor is very common in the aftermarket parts world. I would use it.
