Ac compressor advice
subway
be nice to the admin :D
York PA
Since I did my engine swap I need a v belt compressor. I was hoping I could swap the pulley on my compressor since I bought it new a couple of years ago and it seems to work well.
Does anyone know of a front pulley I could swap on or if the other older compressor I have would be sufficient. I know they made improvements over the years. The older compressor came on my 88 dt360 but I have no idea the history, it does seem to turn over smoothly.
Thanks.
I have a ford fs6 v belt clutch assy. New.
subway
York PA
Would that fit my newer compressor?
Which one in the pic do you want it on, should fit the black one
I know, should be a 10 by quick glance. That's why I was asking.
subway
York PA
I would prefer to run the compressor on the right that currently has a serp pulley on it. I need to convert to v belts for my dt360 engine though.
The compressor on the left has the v belts but I have no idea if it will work well with 134 and I don't know the history of it.
How can I tell what it is? Would more pictures or numbers help?
needlenose
Irrelevant Data
I wanted to do the same when I did the 12v swap since the v-belt is thinner than the serp and I was concerned about spacing. The compressor shop I went to said it wouldn't work. Something about the compressors are different enough that the v-belt pulley wont work. I ended up taking an old FS10 pulley and cutting the center out of it on the lathe. Turned and drilled a new center plate and welded it all up. It's bolted up to the front of the fan pulley. Now I can just buy all stock parts with no mixing and matching.
subway
York PA
That's a good idea but I don't think I have the room for that lol maybe I could do some variation on that idea.
Greg5OH
MI
cant help ya but 2 belts on the w.p. me likey.
Use the belt comp, drain the oil and use oil for 134. Compressor doesn't care what it pumps.
needlenose
Irrelevant Data
Um, yeah, you're a bit real estate challenged there. :)
Is that pulley super rare? If not, just turn down the two outer grooves until you can press a hollowed out FS10 serp pulley onto it, then weld in place. I trimmed 2 grooves off my pulley since the IDI only used a 6-rib anyway. It works great.
If it's hard to get, I wouldn't mess it up.
subway
York PA
Ha! Maybe I should just run an inverter and a window unit out the back. I can even be dazzle the sides so it does not look all red neck like!
That is an idea to turn down the water pump pulley to fit a serp belt.....
The belt compressor is very common in the aftermarket parts world. I would use it.
bob123456789
