ac box foam seal
alienturtle
Human
Ripon, CA
Looking to seal my ac box inside and out back to the firewall. I searched through rockauto thinking they sold the pre made pieces. What are u guys using to seal these back to the firewall? Thanks
Any RV shop will sell the Duct seal on the tape. Thats whats on there now. It works and never hardens ever.
RLDSL
Diesel fuel abuser
Arkansas
In jam , silicone works fine. or you can use this neat black gooy stuff
Sometimes called mastic tape, sometimes called all kinds of things. It's a real mess to work with but it seals thing up nicely and you can set a layer on one surface and it won't smear around if you slip like silicone ( but it will stick and you will have to pop it loose :D
Regular foam can let fumes through to the passenger compartment.
Once you get the box on, have some more fun and get some of that 1/4" closedcell foam with double sided foil insulation and wrap the whole box with the stuff to insulate it from the engine compartment. It will help your ac temps a bunch ;Sweet
subway
be nice to the admin :D
York PA
I used some leftover windshield round seal, it comes in a kit and conforms creating a water tight seal under the hood.
f-two-fiddy
Duluth, Mn.
I've never had a problem with any unpleasant smells, or water infiltration in the cab. The closed cell foam is not condusive to either. The windshield butyl is a good idea too. I jsut didn't have any on hand at the time.
88beast
pa
i used silicone for one section where plastic met plastic and where the stock foam was i went to lowes and got some weatherstripping foam with the adhesive on one side. then selftappers to hold it together works great so far no issues that was over a year ago.
720Diesel
