va350
Having problems diagnosing this issue. I recently replaced my master cylinder which took care of my original problem but after replacing it the ABS light came on and I can't get it to go out. Almost everything is new in the brake system; I've recently replaced rear shoes, drums and cylinders; front pads, rotors and calipers. After the ABS light came on I replaced the RABS hydraulic valve. I am trying to pull the RABS codes but can't get the light to flash the codes. I've grounded the black/orange cable under the dash and nothing happens, the light just stays lit. Any suggestions on what to do next or how to pull the codes. I was going to re-adjust the rear brake shoes this weekend and bleed the lines again.
