jacobbingham
Does the abs light cause the transmission to shift weird? I'll get going down the road and it'll shift so smooth then the abs light comes on and it shifts early and bogs the motor. Changed the rear diff sensor with a new one and it does the same thing. The tps is adjusted to 1.02 at idle. Also will low trans fluid cause this too?
