So, this week was busier than I had hoped for, but I still managed to find time to look into things a bit, and ponder what I want to do with this. Based on apparent parts availability, I have 4 different options the way I see it. I should add that I have spent time this week convinced that each one of these options was definitely the way I should go. From what I can tell, the only pistons and rings that are available are standard size, and .030" over. Bear in mind with these options that I haven't taken the oil pan off yet, but I did plasti-gage several crank and rod bearings 15k miles ago, and everything looked good and was on the tight end of the specs.
My first option is to have the block sleeved and run standard pistons. I would install the reman heads and studs I have already, along with new crank and rod bearings. I would consider cam bearings if needed, and if available (that doesn't look promising). At that point, it would seem like sacrilege to run this engine w/ the pump and injectors that I currently have, so add those to the bill too. And, let's not forget about an intercooler also. The number I got from the machine shop was $2000 to bore, press in sleeves, re-bore and hone, and deck the block. Add that to all the other parts, and it's an expensive undertaking. For me, I cannot justify this option for this truck. This is counter to the mission of this truck
for me. My goal with this truck has been to be an affordable truck that I can rack up miles on commuting back and forth to work, while still being reliable, capable, and comfortable. It's a tool for me. If I go this route, I will end up with another truck that I feel like is too nice to put 40-50k miles a year on. I've already got one of those. The other thing is that I like this truck, but I'm not sure I like it that much. If it were a crew cab 4x4 SRW, it might be a different story, though I still wouldn't want to use it up commuting.
The next option is simply to cut my losses and throw in the towel. I could sell everything off as a basket case project, or piece by piece, and probably not take that big of a bath on it. There are a few problems with this. I don't like to admit defeat. I do still like the truck. And, I still feel like the truck can be made to do what I'm asking of it.
The third option is to clean up the deck surface, slap the reman heads on it, and drive it. This kind of goes against everything that I know, but I drove this truck into my shop. I'm not sure what caused the cracked pistons, but I know that since I've had it, it's never been fed gas, and I've never seen EGT's over 1100*. I wouldn't be surprised if those pistons have been like that for some time. The heads that were on this motor were in pretty sad shape, and I would have to think that a fresh set of heads would have this engine running at least decent. The issue is, for how long? FWIW, I rotated the engine on the stand until the driver's side bank of cylinders was level and filled the dish of a couple pistons with diesel fuel.
They held fuel like that for over an hour. That was interesting to me, and makes me feel like the cracks are not all the way through the pistons.
The last option, and the one I'm leaning towards, is to do a more budget minded rebuild. I don't really think it needs .030" to clean up the bores, but if that's the only thing available, I guess that's what she would get. The machine shop quoted me $400 to clean, bore, and hone the block. I would Clean up the deck surface by hand and check for flatness. I'd also replace the crank and rod bearings. I would keep running the pump and injectors I have for now, but at least pop test the injectors to know what I've got. My concerns with this plan are the potential for cavitation to appear when it's bored, and whether .030" over would be detrimental to the strength of the cylinder walls. I will probably try to piece together some sort of intercooler setup sooner rather than later if I go this route.
So that's where I'm at right now. What are your thoughts?
