A couple front end questions I need answered...(D50 TTB)
ghunt
Morgantown, WV
Starting thursday evening I'm going to be tearing into my front end to do ball joints, u joints, and whatever else I find along the way on my truck.
I had a couple things I wanted to get answers on BEFORE I started.
1. I'm planning to pick up a ball joint press and probably a tie rod puller. Do I need anything else? Do I need to get one of those Ford hub sockets I've seen at the parts store?
2. How much and what weight oil does the front diff need?
3. What thread size are the bolts holding the diff to the housing?
That's all I can think of for now...might have more later.
flareside_thun
Reviving The General Tao
Tavares, Florida
Yes, you will need a hub socket, since you've got the manual hubs, you'll need the one with the 4 prongs. They should be able to give you a capacity reading on the front end but I'm pretty sure it's no more than 2 or 3 quarts of 80/90W gear oil. if you have an LS, you'll also need the friction modifier to put back in there. I don't know about the bolts.....but here's a pic of the hub-socket you should be looking for:http://s.shld.net/is/image/Sears/00...op_sharpen=1&resMode=sharp&op_usm=0.9,0.5,0,0
ghunt
Morgantown, WV
Hm, I'll have to look for that hub socket then...question though, the one you posted says it's for half ton front ends, wonder if it's still the same.
romulus
nor cal
there will be 2 sizes of 4 prong spindle nut sockets at the parts store. you'll need the larger one of the two. i can measure mine tonight and let you know the size.
94turboidi
Ne So. Dakota
I believe its the socket on the left. Its a little shorter but its bigger diameter. It also looks oilier so its probably the last one I used, its been awhile since I had a dana 44 apart.
gonecrazyi
florida
Shouldn't need a fork for the tie rods. Just get a big hammer and hit the knuckle next to the rod with a few good smacks an they should fall right out.
94turboidi
Ne So. Dakota
Thats what I have always done, I have had some pretty stubborn ones though even using a fork. Some guys on here have had stuff pretty rusty though and its a lot harder to get stuff apart.
ghunt
Morgantown, WV
I put new tie rods on the truck back when I was first working on it (Spring of '08), they aren't that rusty but I'd rather have the puller if I need it...y'know?
Diesel_brad
Dunce
gilbert pa
Being your truck is a 94, you "should" have a D50 which uses the 6 prong socket. The one 94turboidi showed on the left
ghunt
Morgantown, WV
I stopped at advance auto parts and picked up the hub socket for $15...so at least I got that taken care of.
olsen726
