oregon-mike
Hey all,
I usually hang out one forum below and just sneak up here when I get roped into helping a friend...friend's '99 crew cab dually, 4x2, powerstroke to get more specific.
Do the newer Fords (with the dial type headlight knob) have the same issues as the OBS & OOBS (is that and IDI maybe?) with the headlights? Namely: running all power through the switch? Her truck has taken to keeping the parking lights on at random times with the switch off. She's taking both negative cables off the batts at the moment so she can start it later.
I did the relay mod on my '93 when my lights starting turning on/off/on/off while driving at night. Replaced the light switch & the socket, did 3 relays while I was in there (parking/lows/highs) and I've had zero probs since.
What do you guys think? Just replace the dial/knob switch in the dash (how bad is that?), replace the switch & do a relay mod?
Thanks in advance!
Mike
Thanks in advance!
Mike
