BigRedWeather
When I last purchased a clutch master/slave cylinder the slave push rod had a plastic clip on it that would hold the push rod back in the cylinder. I don't know of a way to mount the slave cylinder on the side of the transmission without that clip. A picture is attached. I needed to remove my slave and put it back on, but that clip is missing. Does anyone know where I could find one, or would you have an extra? I realize when you use one, it stays with the cylinder.
