'97 Cummins Instrumentation
jperecko
Diesel Ape
Boonies of SoCal
So I am setting up some essential instrumentation for my rig and have some questions. Here is a list of the essentials I came up with-
Water Temperature
Oil Pressure
EGT
Boost
Fuel Level
Fuel Pressure
Water temp- I THINK the stock gauge is electric and the sender is near the back of the block on the driver's side, is that right? If so, is it a 0-5v or what kinda range does it have?
Oil pressure- no idea if stock was mechanical or electric. Where is the sender or a good port to hookup a mechanical line?
EGT- already have the probe and that is obvious... no issues here
boost- same as above
fuel level- is going to be stock... but anybody happen to know what kinda range Ford originally used?
fuel pressure- I did the fuel system so no worries there either
I guess the big questions are how Dodge did water temp and oil pressure.
thanks in advance for any help
jperecko
Diesel Ape
Boonies of SoCal
bump... anybody? I got the fuel level buttoned down but still need some help with water temp and oil pressure.
Bradz
