94 Dodge 2500 5.9L Died/cranks but won't Start
wildbill_hickup
Truck down, stange smell inside cab (not burning wire) like break fluid or a small amount of either. Pulled into a store lot and engine died. Have fuel, all gauges OK last time I looked before failure, no noises prior to failure. Just died!!! Checked autoshutdown relay to see if it smell burnt, seems OK. Fuel in fuel filter,no water. Help!!!!!!!!!
wildbill_hickup
Checked fuel shut off, wasn't pulling up. Turned ign on and pulled up manually. it stayed in the up/on possision. Truck still won't start. I have never had a problem before yet now I have to pull the solinoid linkage up manually every time, and truck still won't run. Had to come back to the house to get another wrench, will try cracking injector line to see if I get fuel when cranking. I am getting fuel at the return line to the filter when using the priming pump so I know there is fuel in the tank.
m2rtin
