Grind the plate!
I would recommend the Con OFE unless you are absolutely certain this truck will be running more than 450RWHP. I had a 13" FE in my previous 97 running 430RWHP and it was a little grabby & aggressive for my taste's. Should have listened to Peter and got the OFE instead and saved some $$....really since I sold it 5 months later!
Give JR Adkins a call 317-281-3130 he can set you up with a great turbo at a good deal less than a B-1 price tag. Not knocking B1's just trying to save you some $$
I would recommend a Scotty II intake with the cowl hole cut for air intake, it reduces EGT's DRAMATICALLY!
I would waste money on the AFC spring right away. You can usually adjust smoke level's with AFC spring/housing and plate adjustments. Save the $$
Again, check with JR on the DV's he has the best price on the market!
Spend the $35 you saved on the AFC spring to install a new OverFlow valve!
Inspect your exhaust manifold VERY WELL before laying down $$$ for an ATS yet. Sorry but I'm not parting with $400-500 big ones until its necessary!
I would say go ahead and get the PDR boot kit, cause once you start increasing boost past stock level's its only a matter of time before the stockers start failing. I'm going to be ordering PDR's in about a month or less. Need HD valve springs & 4K baby springs first!
Lastly, Rip Rook for the best price on exhaust system's.
www.SourceAutomotive.biz
I think that about sums it up, before you lay down the $$$
