YJMike92
Yes, real Dually wheels in the front. It does appear to have aluminum wheel spacers in place of the factory dually hubs. I will have to investigate a little further.
I wasn't trying to suggest that either company did the conversion. I only was using them as examples of big companies that do/did quality jobs.
The hub assembly between a Dana 50 (TTB or Straight axle) and Dana 60 are interchangeable..
Hub assembly's from a dually dana 60 can be found, and its a very easy swap.
If you have a dana 44HD (which my 88 idi has), then spacers are your only option. The front wheel spacers that Ford used are a parts unicorn.
Look inside the rear wheel wells. Centurion did a hatchet job on the Styleside box to clearance for the inside dual, then added the dually fiberglass fenders to the side of the box. I have an '87 F350 4X4 Styleside Centurion that was converted to a dually this way. I have 2 Centurion F350 conversions and you are right that there is typically a Centurion identifier somewhere. Plus, Centurion used different markers on the dually fenders. Yours looks like it has factory dually markers.
