89 F350 DRW with a PSD
a new side job came in today.
89 F350 2wd CC DRW 96 7.3 PSD
i need to make as much $$ as i can for my new boat!
this guy had his truck at a local shop, and they royally *****'d him.
so, he heard from one of my customers that i would do something like this.
hell i have 2 powerstroke swaps that im in the process of, so why not another?
i told him, that ive brought a 01 7.3 back to life, and that my IDI is my daily driver, both i received totally trashed.
im no expert, but i can do the work for a rate of 65/hr, minus research time.
however long it takes me is how long it takes me.
this is a hobby, but it will be done right, and not hacked!
but, the truck is hacked to begin with.
today i installed the engine plates that i bought off a member.
the previous shop just put the engine in on the f'n crossmember,
dummys. and welded this plate to the bottom of the crossmember. (if you can call this welding)
so the plates are in and the engine didnt have to come out.
i sold him a early GTP-38 that i scored on e-bay, and i wanted to use, oah well his TP-38 is junk, scrapes with a simple turn of the hand.
just waiting on a new pedestal with the EPBV deleted.
new up pipes.
new battery cables
the truck has a ZF5 and a GV ready to install.
BrandonMag
Dana 50 rebuilder
Oregon east
Those are some of the worst 'welds' I have ever seen!
Good luck with the rebuild, I'm sure there's some more nasty surprises lurking in there.
i can blow my nose in my sleep and have more penetration!
dont f'n jinx me! lol
the only thing the shop did was place the engine in the engine compartment and rhino lined it....
then he told them to stop.
i really really dont see how one can weld this way.
at some point doesnt one say " woah, this isnt working"?
sooooo, did a bit of work on this a few days ago.
these ********* used standard bolts for the transmission.
one of them is cross threaded.
the other 5 i didnt have a problem replacing with the correct metric bolts.
up pipes, down pipe, and EBPV delete pedestal are in. (as in delivered)
i went to install the turbo, and BAM the wastegate hits the damn cowl.
time to break out the grinder and welder and make it fit...
hopefully get that done this weekend.
97 PSD, early 99 turbo with 1.10 intake snail
the intake Y does not fit.
gonna have to find one or modify one.
but the UP pipes do....
jut out a section of the firewall so the wastegate will fit
this is just a test fit right now, ill fill in the gap later.
turbo clearance.
turbo.
intake.
up pipes.
all final installed.
dont have the 4.5" flange for the down pipe.
lots of parts ordered/delivered.
truck is in the shop.
business has been crazier than a redhead on the rag.
may get to work on it this weekend.
i have to work on a 6leaker in the AM, and then hit the water.
maybe sunday.
got the down pipe done, exhaust complete.
old 460 wiring stripped, still waiting on the intake boot i purchased from riffraff.
need to do body work on the E350 next.
and a special thanks to "fastestIDIinthe707" for the trans plate!!!
another 10 hour day on the books.
swapped out the core support today,
installed computer, and engine harness.
installed both battery trays
swapped pedals from auto to manual
now i gotta pull them again to fetch the stock wiring and install the new wiring.
radiator fits like a glove.
deleted some of the underneath wiring.
addressed fuel tanks, but didnt get anywhere.
ordered parts.
i wish i woulda worked on my truck!
time to do some dash wiring....
may be looking to convert it to an OBS dash
F350camper
BOOST!
Man! I'm a hack welder at best. And I always tell people, just because your welds aren't pretty, don't let that keep you from welding. But holey crap, that weld put the U in UGLY. :shocked:
as the cuanuks say,
" THATS CHICKEN DODO.
you know when you grab a chicken by its neck and it craps all over you- RiotWarrior"
:rotflmao
REM70
