87 Crew Cab w/ 6 doors
madpogue
Madison, WI USA
So, years from now, when you've got it down to ONE color (or better, two, but as a real two-tone), are you gonna admit to them that they took their first ride home in a... what.... SIX-tone truck?
(And the $64,000 question - which of them is eventually gonna get the truck?.....)
both of them will get the chance to EARN their own trucks when the time comes.
they will not be "given" anything they do not earn.
the 6 door is mine.
for now, and forever :D
madpogue
Madison, WI USA
Didn't say anything about "giving". People can _earn_ what they inherit from their parents (believe me, with one exception, my siblings and I did.....).
the 6 door is mine.
Okay then, I suppose they're gonna arm wrestle for who digs the hole to bury you in it, eh?
HOK KD2000
EDITED:
house of kolors does not sell the KD2000 anymore thanks to the EPA.
their equivalent is KD3000 which is not a good primer...
glad i have just enough to finish the truck.
this is a water based primer that will crack on you.
ive seen it done
GENIUSLOERTS
arkansas
The water based stuff is very interesting. it is defiantly changing the auto painting game
big plans today went down ye ole crapper.
ROUND 2! ... FIGHT!
So, i started on the next round of mods for this truck since which i believe a head has cracked.
alot of things will be taking place.
at the speed, i do not know.
i want this to be my daily driver.
anyways before i get into what has transpired today, let me tell you the check off list.
engine-
new heads
new cam
powder coat alot of crap
new roller rockers
new turbo, ATS 093 w/ WW2 built by Russ.
same IP & injectors.
replacing holley red w/ holley black w/ regulator
rebuild oil cooler
steam clean everything and paint.
new paper filter, get rid of the POS K&N SET UP
new racor filter and water seperator.
delete stock fuel filter location, and run it after racor, underneath
new o-rings, same return system.
new lifters,
need shorter pushrods (TBD)
power master starter.
replace rear main seal.
replace oil pan
chassis,
install custom anti axle wrap device
new red box gear bopx
aluminum fenderwells
hydroboost system.
maybe spring replacement.
new shocks
on board air
AC
new bumpers
a flatbed.
may change rims and tires.
will not be lifting truck.
body,
replace 4 doors, (pass front, pass middle, pass rear, drive rear)
new doors are super clean, and no body work required.
re-direct cowl to the pass side.
delete conventional battery trays(place them in the flatbed)
install 2014 badges.
delete existing badges.
fix hood*** see below
make camper box.
fab up complete roof rack.
and where ever the stars take me.
today i thought i was gonna show you how much of a badass i could be.
i started tearing the truck apart around 11 am.
i disassembeled everything to pull trans, transfer, and engine for the engine work.
about 2 hours into it, all i had to do was remove the trans, starter, turbo, trans body inspection cover
power steering hoses, and oil filter.
everything was golden until this point.
i started with the power steering hoses,
i went to cut the return line, and replace it, but when i did, i realized it was new trans line and a hose clamp that was easy to get to.
disassembled feed line & return line, no issue.
went to pull the turbo off, with the exhaust cross over off, and the Y.
because of the injection line system still in tact, i couldnt get it to clear the cowl.
had the bright idea to undo the rear trans mount and lift it up as much as i could.
BINGO! turbo came right out. besides the olives being complete crap, everythings Aok.
removed trans cross member to pull trans (with transfer off)
i really did try to remove the trans while leaving the inspection cover.. wasnt gonna happen, the selector hit the cover.
grease on my seats at carpet...
this is where things went down hill.
took me 25 f'n minutes to remove the G'd starter, because i misplaced my 13 mm swivel head. (the perfect tool for the top starter bolt)
pissed.....
time is 3 pm now.
went to take the hood off.
mind you, im doing this myself, no help in sight.
got the driverside spring and hindge off, and 3/4 of the passenger side off.
the last thread on the last bolt and a gust of wind sent my hood barreling twards the f'n ground, mangeling the driverside corner.
-SUPER PISSED.
i tried to leave as much alone as i could. it bit me in the ass.
got everyhting ready to pull the engine.
and BAM engine was gonna smack the inner cooler.
removed it...
lifted the engine up more, and BAM decided to pull the windsheild wiper motor.
at this time, by brother shows up.
i ask him to help me guide the engine out, and as soon as the exhaust manifold was about to reach the clutch slave, forklift dies.
out of F'n propane!
got back, took my medication, drank 3 beers, relaxed, and the rest of the pull went like clockwork..
im bringing this thread back to life, because my truck is about to under go some major transformations!
atleast todays over, tomorrow is a new day. ride it like you stole it!
7 AM
11 AM
12 PM
2 PM
3 PM
4 PM
5 PM
madpogue
Madison, WI USA
"Woman, get out here and help me with get this engine out. The twins can feed themselves, can't they?"
P!$$er about that hood. Good thing you weren't clocked by it. One of those times when the wind doesn't blow, it sucks.
Ruh-roh, rhaggy, there's a truck that's more colors than yours - http://scranton.craigslist.org/cto/5166355831.html
(More space for little humans, or big-boy toys?)
the woman and the kids were at her mothers,
she couldnt reach if she wanted to lol
up with a cryin baby for the past few hours, so after i an able to finally get some sleep, ill be steam cleaning everything and tearing the engine apart.
i need to go buy a HF engine stand, neither of my stands will hold an IDI.
be back soon with an update.
Waystro
No Class
South Texas
Ahh the joys of pulling the hood by your self. Mine got dented on the passenger side.
Now that starter is a B*+#* to get out 2 hours of fighting is what it took me. -cuss
At least you got your engine pulled still waiting on my coworker to bring the Hoist over so she just sits there.
F350camper
BOOST!
USA
Its funny to me, why do mechanical things try to fight us? Don't they know by now that we always win? haha looks like you got this, hands down...
unfortunately,
i missed out on a 5k deal that was supposed to fund this project.
i have 90% of the parts
so, i will be doing this as cheap as i can, or stopping at certain points when im outta dough.
someone buy my front bumper ;Poke
big boy poker run. the day started off envious like a ****.
spent some time with the heathens.
old grumpy dawg has gotten pretty protective of them!
all i did on the truck today was steam clean.
