87-94 Glowplug harness...
ManicMike
Bear, DE
My '92's has seen better days. I was wondering if it's possible to make a new one? I don't THINK it'd be that hard, but you never know.
-Mike
Diehard450
Bonney Lake,Wa.
I had asked the same thing, Someone had replied that the mainline (power supply for glowplug's ) is one wire and that each plug has a short lead for each plug leading off of it. That is if I understood him correctly. I maybe be wrong but that's how I understood it. I still haven't repaired mine or replaced it, but intend on doing it. good luck with it!
Marshall1
King county
thats how mine was. I made a new harness for the driver's side since the PO thought it was OK to just wrap electrical tape around the burned glow plug connectors and call it good.:rolleyes:
Its not hard to do just use the proper gaude wire and bullet connectors.
ManicMike
Bear, DE
What gauge wire would be good then?
bike-maker
albany, OR
Mine had 2 10 gauge yellow wires going from the starter solenoid to the glow plug relay. They both hooked to the same terminal on each end.
Marshall1
King county
on mine the wires for the glow plugs were brown with unusually thick insulation, but I do believe that they were 10 AWG. I ended insulation my wire with fiberglass sleve as any extra precaution aginst heat and chafing.
riphip
Memphis, TN.
Bought a new complete harness at uhaul parts. $188 + shipping. Take one off put the new one on.:thumbsup:
Rick
ManicMike
Bear, DE
Rick
Sorry I'd rather save $168 and make my own in a afternoon's time. Guess I'll be pulling the old one off and copying it.
sle2115
NRA LIFE MEMBER
Southeast Ohio
I was into mine not long ago...the heavy wires on the solonoid end are fusible links. I did away with them, ran 4 gauge battery cable with a 250 MAX fuse from the solonoid to the controller. Works like a charm, but doesn't fix the glow plug end issues.
