Greenbeast6.9
grease monkey
Testing the waters with this: Its a extended cab long bed that i converted into a 4x4 using a 77 Dana 44 8 lug. i put the shaft and the tail housing on the c-6 and put a np208 on with drive-shafts.
the motor is a 6.9l with a lot of NEW parts like an injection pump, injectors($300) alternator($100), starter($150),radiator($350) is also new as well as the batteries.it also has new booster and ,master cylinder($100) Also here is the kicker, it has a brand new hypermax turbo that is less than 2 months old!!($1800)
it has the 10 1/4 rear with 4:10 gearsand 5000# airbags the front is a 44 with the same.
ok here is what is wrong with it, it needs head gaskets for sure and a possible rebuild, the moor runs but has a tick to it that im not sure what it is.
It also needs a driver side glass and the vacuum pump is going south on the motor.
overall i dont want to let the truck go but i found something else.my loss is your gain
$2600obo
$2600obo
