86 c6 forward clutch assembly
gem6.9
lebanon, or.
hello,after rebuilding the c6 and installing it and finding i had reverse but no forward unless reved way up , i pulled it back out today and found the seal rings broken in pieces on the forward clutch assembly and the new clutch dics worn to the metal. i will be ordering some new parts and try it agin. those are clled lock seling rings and i must have not locked them. greenhorn mistake and i hope this helps some body out later. i will post when i get it done and see if it works better,thanks for the help.
RLDSL
Diesel fuel abuser
Arkansas
Ouch, that sucks! Mark one up to the learning process. You should have it licked next time ;Sweet
david85
Campbell River, B.C.
Yeah that does suck. I won't even tell you the number of things I screwed up with my E4OD before I got it right. I will say it could have been worse! Hope it works this time and good luck.
