gem6.9
hello,after rebuilding the c6 and installing it and finding i had reverse but no forward unless reved way up , i pulled it back out today and found the seal rings broken in pieces on the forward clutch assembly and the new clutch dics worn to the metal. i will be ordering some new parts and try it agin. those are clled lock seling rings and i must have not locked them. greenhorn mistake and i hope this helps some body out later. i will post when i get it done and see if it works better,thanks for the help.
