rembrant88
A few of you might remember what I'm working on. 1994 7.3 idi turbo. It had a bad lifter bust up the push rods on #2 cylinder. And when I say stuck I mean stuck in the slot. I got its buddy out but the one that started this problem can be lifted about 1/2" and no further. When I tryed to pull it out the first time I heard a piece of it fall into the oil pan. I want to pull the little fella' out without taking the engine into a shop, but as you can imagine I try to shy away from brute force when dealing with engine parts. That's about what it would take to remove. My thinking is to pull the cam and let that one fall through. I just don't want to pull a cam until I find out if the cam lobe is bad. I don't even know what would cause it to jam in there. Unless the cam is bad and wore a spot on the lifter that is preventing it from coming out.
So the question is, assuming it budges, is it okay to scar up the bore as I pull that lifter out? Will a little damage to the slot cause a problem?
Anybody have any other ideas on how to get that thing out?
