7.3 shuts off abruptly.......
Diesel D
Kaukauna WI
Hi everyone. New to this site. My '02 F-350 7.3 starts and idles fine. Then, after 10 minutes or so of idling, it shuts off abruptly....no sputtering, then will start right back up. Check engine light is on. I don't have a code reader, but would be interested in getting one. Any suggestions?
greenskeeper
PA
you really need to get the code read, the PCM is telling you what is wrong.
On a 02, many should work. I would still start with a bluetooth obd2 adapter, with torque pro. (If you run android)
Diesel D
Kaukauna WI
...thanks jasper....unfortunately, I'm old school....I don't have a smart phone....are there any separate units you would recommend?
Look into a usb to obd2 cable, then run forscan on your laptop.
Or go all out and buy autoenginuity. (Around $400)
lotzagoodstuff
Carmel, IN
If you have a laptop, get a bluetooth dongle and use ForScan. It should tell you everything you need to know for under $35.
My bet is IPR, but I just like to gamble :)
Just have to make sure the laptop is bluetooth compatible first. That's why I recommended the usb one. Lol
