7.3 NA Idi e350 belt squeek/wobble (vid)
Christian9112
California
Im not sure if this is normal but there is a wobble between the alternator and engine pulley that I didnt notice before putting in a new alternator. So I changed the tensioner and idler. After the tensioner was changed the squeels started. The old one seemed stiff but didnt squeel as much. (not that I noticed.)
would this be catastrophic to drive? I need this truck for work.
Christian9112
California
The new alternator is upgraded from 90A to 165A
The belt is around 1000 miles.
I notice that the distance between the pulleys are pretty far. Im just concerned about this squeek
Ironman03R
Risingsun, OH (NW OH)
Maybe the tennsioner had a different diameter pulley than the old one. Maybe try an inch shorter belt. You could also put an idler pulley on the back side of the belt on that long span.
DrCharles
West Plains, MO
Where is the tensioner in its operating range? You should have to pull it all the way over with a breaker bar to even get the belt over the pulleys. If it's too loose it will definitely bounce and squeak.
If you're going to try a shorter belt I suggest half an inch (depending on how tight the one you have now is). You'd be surprised how much difference that makes to the fit :)
Christian9112
California
Ok thanks guys! I will try a shorter belt first. If that doesnt work im gonna make an adjustable bracket for the alternator with an idler on it.
