7.3 IDI leaking transmission fluid into motor oil
Discussion in '6.9L IH & 7.3L IDI Diesels' started by wrgallant, Jun 18, 2012.
  1. wrgallant
    wrgallant Registered User
    Jun 18, 2012
    ipswich MA
    I have a 94 7.3 idi turbo that leaks transmission fluid into the motor when the transmission cooler is connected. I plugged the transmission ports that feed the cooler and the leaking stopped. My guess is that the cooler is causing some sort of pressure difference that is forcing the fluid into the motor.
  2. OLDBULL8
    OLDBULL8 Good Morning Ya'll. Supporting Member
    88
    9,563
    36
    There shouldn't be any connection between the engine and transmission. Are you talking about an auxilliary transmission cooler mounted in front of the radiator? You do have an automatic trans, right?
  3. Agnem
    Agnem Using the Force! Staff Member Supporting Member
    54
    16,963
    42
    Where is this "leaked" transmission fluid showing up? In the motor oil, or the coolant. If in the motor oil, how do you know that this is happening?
  4. riotwarrior
    riotwarrior Supporting Member Supporting Member
    52
    14,104
    22
    Sounds like a leak in a rad tank cooler to me! Getting trans fluid into the coolant and contaminating the coolant, caused by pressure differential of trans pressure and coolant pressure
    maybe wrong...
    JM2CW
  5. trackspeeder
    trackspeeder Stone crusher.
    52
    3,752
    Dec 21, 2003
    North Branford. CT
    X2 Coolers can fail with age. A good radiator shop can fix it.
  6. wrgallant
    Jun 18, 2012
    ipswich MA
    Transmission fluid is showing up in motor oil - I can tell because motor oil level goes up and trans fluid level goes down.
  7. wrgallant
    Jun 18, 2012
    ipswich MA
    EO4D transmission - fluid gets into motor using radiator cooler or auxiliary cooler.
  8. wrgallant
    Jun 18, 2012
    ipswich MA
    I get transmission fluid in the motor oil with an auxiliary cooler with no fluid passing through the radiator.
  9. OLDBULL8
    88
    9,563
    36
    There is no way for transmission oil to get into the engine crankcase oil, in a normal engine, transmission hooked together.
    Surely, no one would hook the transmission cooler return line into the engine.That would be the only way it could get there.
  10. paulw
    paulw paulw
    48
    Mar 3, 2012
    salineville ohio
    you have my attention now iv been working on cars for over 20 years i never heard of that
  11. FORDF250HDXLT
    FORDF250HDXLT Home Sweet Home Supporting Member
    5,298
    405
    Dec 27, 2009
    Maine & Oklahoma
    this is gunna be good.
    :popcorn
  12. wrgallant
    Jun 18, 2012
    ipswich MA
    Would an external cooler lower fluid pressure in the transmission? I had the transmission off to replace the flex plate over the winter. Could I have damaged a seal?
  13. justinray
    justinray Contributor
    25
    1,141
    Jun 24, 2011
    Cleveland, Tx
    Could you damage the seal? Yes, but a damaged seal would leak oil out, not tranny fluid in, fluid always goes from a high pressure area to a low pressure area, the crankcase isn't necessarily what I would call a vacuum.
  14. justinray
    25
    1,141
    Jun 24, 2011
    Cleveland, Tx
    && no, the external cooler should have no effect on internal pressures.
  15. wrgallant
    Jun 18, 2012
    ipswich MA
    Could the cooler cause the transmission fluid pressure to be higher than the crankcase pressure?
Share This Page
