7.3 IDI E4OD parts for pulling the pump and more!
tbrumm
Richland Center, WI
Well, it does not look like I will have to pull the pump on my E4OD again anytime soon (yeah, I know, I just jinxed myself!). I bought the small parts needed for pulling the the trans and splitting the pump, so I may as well sell them to somebody who could use them. Parts I have: qty 9 E4OD pump bolt washers, qty 1 E4OD pump stator support washer, qty 1 E4OD pump o-ring, qty 1 E4OD pump gasket, qty 1 RACERX High Performance front pump seal for the E4OD. All together, these parts cost about $30 before shipping. I will also include a new repair pigtail connector for the MLPS (neutral safety switch) (was $14) and the ATSG repair manual for the E4OD (was $25) . I also have a used solenoid body with about 95K on it drilled for the TRANSGO Tugger kit. I replaced it with a rebuilt one thinking it was bad, but it is probably okay - won't guarantee it though. It is up to you to tell me if you want it and I will send it along. I also will include a new, never used glycerin filled 0-500 psi pressure gauge which you can use to check the line pressure of your trans (you will need to buy the proper fitting and hose separately). I will ship all in a priority mail large flat rate box for $60 to your door. If you want pictures, pm me your email address. Thanks for looking
tbrumm
Richland Center, WI
Here is pic of the parts - couldn't get this inserted into PM. I will send you another PM
Nanohawk
