Tarantula
Hello, I am new here, and like many, I have a question (and unfortunately, a problem). I am having trouble with a 1987 ford 6.9L normally aspirated diesel engine. It is running rough with lots of blue/white smoke and is down on power, my problem started suddenly while driving at highway speed with a fully warmed up engine. I have verified that the engine is receiving enough fuel at the specified pressure, and the fuel is clean and of good quality, I replaced the fuel filter and have replaced fuel lines to the tanks.
I have noticed something while working this issue, and I am wondering if anyone has ever noticed the following: I filled the fuel filter with ATF ran the engine for 30 seconds, and then let it soak. I fired up the truck after about an hour had passed, and the engine was running quite well at idle, almost like a normal diesel should. As the ATF in the filter was used up, and the engine began running pure diesel again, the engine returned to blue/white smoke, missing, barely stay running behaviour. It seems like the ATF might have made the injection pump work properly for a short time? Or does ATF simply have more energy for burning? Maybe a coincidence? Has anyone ever seen this happen before.
I appreciate any responses, further more, I sincerely appreciate the weath of knowledge that has been shared in this forum since it's inception by the members of oilburners. Thanks!
