I have a 1986 F350 that I put a 7.3 IDI in. The truck was originally a 460 gas job but I decided to do the diesel swap. I found an 86 F-250 6.9 that was junk and I was able to get it for the wiring harness. I pulled the wiring harness out of the 250 and put it in my F350 in place of the gas engine wiring harness. The engine I'm using is a 93 7.3 IDI from a truck with an automatic transmission. It will now have a four-speed transmission.
What I am trying to do is connect the two wiring harnesses from the engine to the truck harness. Wiring is not my strong suit so to say. I have a couple of different manuals for the 1986 truck and I went online and found a couple of different wiring diagrams for the engine harness.
I know I am not going to need the throttle position sensor and I read it's only one wire for power to the injection pump. I'm not sure what other wires go where in terms of sensors the glow plug warmer and idiot gauges.
I know there have been plenty of these swaps but I'm having trouble locating diagrams and tips on how to do the wiring. I had a post over on Ford truck enthusiast but not much help there so I figured you guys over here might be of help with this wiring. Any help would be greatly appreciated at this point because I'm at a standstill in my build project now until I get the wiring done.
Thank Bob
Thank Bob
