As I said in my last post. I recently purchased( last thursday) a 1986 F250HD extended cab 4speed 4X4 with a bad motor. I tore into the front axle(dana 50ifs) and replaced the axle shaft u joints at the steering knuckles, repacked wheel bearings, installed new rotor on the right side and new front brake pads. On sunday I pulled a good running 6.9 out of a 1987 E250. I am hoping to install this engine in my truck tomorrow. I have noticed some differences between the 2 engines. I am wondering which differences are due to the engine being a 1987 and what is van specific. I noticed the the glow plug contol relay is different on the van engine and also mounted at the rear of the engine under the air cleaner. I would like to use this set up but it is different than the one one my F250's engine.What will I have to change wiring wise to use the newer relay? The fuel filter is also mounted in a different position on the engine. The van engine is on the left side of the valley, while the pickups filter is mounted behind the alternator. Any advantage to one location vs the other? I'd have to switch feed lind from filter to IP if I stick with the alternator mount on the ex van engine. I will be using the flywheel of my truck engine rather than the flex plate from the van. Any special considerations when doing this? Thanks for the responses.
