DIS mistakenly sent me a 7.3L pump for an 89, when I have a March 1984 6.9L. I figured, no big deal, the two pumps are similar enough they will work. Is this true? Are the 6.9 and 7.3NA pumps interchangeable? I am still in the preocess of rebuilding the truck/engine, but this all came about when DIS called to REJECT the original 1984 IP I sent them. They said they do not deal with the earlier IPs!! It worked fine, so I'll try to get it back and get a 7.3 core to send them. Upon talking further with DIS, they said they don't recomend using the 7.3L pump on my 6.9. Should I keep the 7.3 Pump and use it, or send it back for a 6.9 unit?
Thanks in advance,
Peter
P.S. A little update on the project; the '84 chassis and body are no more. On a sour note, turns out the 5 speed I was to use from the 89 had a MAJOR crack in the bellhousing, so it looks like I'll be sticking with the trusty T19. Oh well.
Thanks in advance,
Peter
