it was my understanding that the 6.2 is externaly balanced with the flywheel. however while doing research for an engine swap two people said that its the harmonic balancer that is how the 6.2 is balanced.
here is what i'm working on and i don't want to break the crank shaft or have other troubles;
'68 M715 w/
6.2 diesel from a cucv
3053A OD tranny from a duece and half
NP205 divoreced
Dana60/coperate14B 4.56gears 38"tires
anyway, can you all confirm if the 6.2 has a balanced flywheel or can i use other flywheels and its the harmonic balancer i need to worrie about.
thanks
'68 M715 w/
NP205 divoreced
thanks
