As 79Jasper stated, you need a sensor and a gauge:
https://www.auberins.com/index.php?main_page=product_info&products_id=271
https://www.auberins.com/index.php?...earch_in_description=1&keyword=pressure+gauge
You can get a dual gauge that can also receive and display an EGT value (if and when you want to add that), in addition to the fuel pressure.
Isspro also sells sending units and gauges, so does Autometer.
You will need an M12x1.5 to 1/8" NPT fitting and it will install in the fuel pressure test port located on the fuel pressure regulator (on the side of the secondary fuel filter housing/bowl):
https://puredieselpower.com/ford/ford-6.0l-powerstroke-fuel-pressure-gauge-adapter-fitting.html
http://www.dieselmanor.com/diy/images/FTG-FPA60_installed.jpg
https://cimg7.ibsrv.net/gimg/www.fo..._daeb8877e70d3e81db951f633687a9dfaab606a2.jpg
https://www.ford-trucks.com/forums/1224845-fuel-pressure-gauge-for-tech-folder.html
I used the "Driven Diesel" extension hose in order for things not to be so cramped. The link below can get you the hose AND the adapter:
https://www.strictlydiesel.com/p-2671-driven-diesel-60l-fuel-pressure-adapter.aspx
Some people have purchased a billet fuel filter cap that has a port on the top for a fuel pressure sending unit. I personally don't like that option.
