6.0 making oil help!!! Not injectors
reh4960
Edgewood, NM
So I pulled fuel lines off the head and connected 125 psi of air and nothing no air noise coming from under valve covers. Do I need to turn the key on so fuel gets to all the injectors? I didn't pull the covers but I stuck my ear over oil fill and breather hole and it was silent.
reh4960
Edgewood, NM
Might be fixed fingers crossed. Pulled drivers side valve cover put air to fuel port and saw #2 injector was leaking from injector body. Took it out then apart replaced oring old one was hard and very brittle checked next couple they were fine but still replaced orings. Didn't check passenger side probably just drive it few days see if oil rises or not.
I would almost put money on that cylinder having a sealing issue. Probably didn't check the bore?
reh4960
Edgewood, NM
I looked in there it seemed normal. Could there be a crack ? Or something else like bad cup?
bismic1
Texas
RustyNail351
