5.9l cummins white smoke
rustygold
conway Arkansas
Was driving down the road running fine then power went away then a cloud of white smoke. It's smelled like diesel.
It's a new rebuild on the motor.
Sent from my SAMSUNG-SM-G870A using Tapatalk
rustygold
conway Arkansas
Oops 5.9l cummins 12v new everything but 2 month old injectors original injector pump.
It's only had about 3 hours on the motor I rebuild it ran it drove it around felt great. next day started it up drove up a hill doing a small load test big cloud of white smoke comes out get it back to the shop every time I give it gas it puffs out white smoke.
Tomorrow will be collecting more data
Correct. You never know.
But right now I would be leaning towards a fuel problem. Double check the injectors. Check fuel pressure.
rustygold
conway Arkansas
I'm going to do a leak down test and have the injector tested make sure they are fine.
Should cummins have about 2psi before the injector pump like 7.3idi or higher?
rustygold
conway Arkansas
Ok well its doesn't want to start anymore just when back and check timing it's off from the pins. Going the pin on the motor lined up the injector pump pis is way off
rustygold
conway Arkansas
When I found out about that killer pin as I rebuilt it I did that mod to it
rustygold
conway Arkansas
Well try to start it this morning it was not cold but it didn't want to fire up or even hit a beat.
So check the timing on it it looks like the pump is a whole 3/8 of an inch off advanced so maybe that's the problem.
Could not change the timing had to get a coil for my other 5.9l cummins it didn't like running on 4 cylinders
dented73
