5.0 to 7.3 Project
gregmiller185
Saskatchewan
Hey new to the forum, hoping to use this to ask a few questions and share some pics of my project.
So I started with a 87 f250 5.0 with a 4 speed. And recently picked up a 92 7.3 with a banks sidewinder, E4OD and a trashed body. Both trucks 4x4.
I originally intended on swapping the motor/trans/tcase and axles to my 87 but then decided to just swap the 87 body and lift over to the 92 chassis. I am by no means building a show truck whatsoever, just something I can use and enjoy.
Here’s where I’m at.. I plan to use a baumann quick 4 to run the tranny but they are currently updating the displays or something? and looking at a couple weeks for that plus this virus is causing delays as well and not to mention the Canadian dollar has plummeted since I first talked with them. I’d be looking at 1500 Canadian by the time it’s to my door.
So I’m thinking of putting that on hold and wiring in the factory controller if possible. The harness i have is pretty chopped up but all the plug ends are there and I’ve found the wiring diagram for the E4OD which I will try to post.
What I need to know is if this is possible without using the 92 dash? And if so are there any circuits I do not need? I will pretty much be making my own harness.
Looking like I may have some time to play with this Or should I just fork out the cash and wait for the baumann?
E4OD wiring diagram: (hopefully that works)
http://askatech.com/AskATechLive/forums/ResourceHandler.ashx?a=7489
gregmiller185
Saskatchewan
Here’s how I got the truck.
A month later.
The 92.
The body is currently on, suspension swapped, diesel core support, fuel tanks work, etc. etc. just haven’t got pics of it yet.
Does the 92 have a speedometer cable? I forget when they went to a electronic speedometer, but you are getting close to that year. If it doesn't and you want to use the 87 dash and wiring, you may have to swap in the 87 transfer case to get a speedo cable hook-up spot.
I think the factory controller, and probably the baumann also, need a speed sensor to detect road speed, and they also may use something from the engine to detect engine rpm. Other than that, both controllers are pretty much self contained correct?
If you use a manual button for the glowplugs, and find a hot key-on wire to run the engine, you should be able to use the 87 wiring.
chillman88
Central NY
I believe all the years use Tach for RPM signal and the signal from the rear axle ABS tone ring for road speed calculations. I may be wrong but I was under the impression the TCM gets those signals regardless of the style of speedometer?
This is from information gleaned from the internet and definitely subject to correction!
gregmiller185
Saskatchewan
No this one does not have a cable. I believe it’s the first year they switched. It does have the speed sensor in the rear diff which is all the baumann controller needs and would obviously be required for the factory computer too but not sure if the PSOM (I believe it’s called) is also needed?
I’m okay running without a speedometer as it was not at all accurate with my tires anyway. Might just throw some sort of digital GPS thing from eBay in it for now.
I have been able to use most of the 87 harnesses. Just had to modify it for the electronic fuel selector valve and alternator/charging system. I also used the 92 under hood fuse box to power the glow plugs/fss.
chillman88
Central NY
Well I have no clue but since it wasn't even on the pre 92 trucks and the transmission was the same until 94-95 I would imagine you could use a TCM from an 87-91 with the E4OD.
gregmiller185
Saskatchewan
That’s kinda what I’m hoping.. but would be awfully sad to make a harness just to find out I need the 92 dash module.
gregmiller185
Saskatchewan
Funny how quickly they snowball huh LOL
Ya no kidding! All well.. gives me something I enjoy doing during these times.
Never thought of using the pre 92 TCM. I wonder if the entire harness would plug right into the round 50? pin connector keeping me from having to make my own harness. Hmmm
I’m pretty limited as far as wrecking yards go here. But I’ll maybe call around, hopefully get lucky
u2slow
bilge rat
Coastal BC
With those big tires, I'd just run the 4spd... or swap to a ZF5 setup (very cheap these days, not like NV4500s).
aggiediesel01
Houston, TX
If you have all the '92 wiring, underhood and underdash, it should pretty much lay in place in the '87 body and pretty much all the controls and functions are the same. You'll have to pull the dashes on both to swap the harnesses but the '92 harness should lay behind the '87 dash with minimal effort. Since your e4od is early it may have a provision already on the tailshaft to install the speedo gear/cable that was used with the '91 and earlier style trucks. That would be less work than trying to splice the two years and different fuel types together.
Cv axle
