So for those that have seen/read my first thread on Oilburners I'm trying to resurrect my 98 5.4L E350 EB in the form of a 92 7.3L IDI E350 EB Ambulance...
without adding too much confusion I'm curious to know if anyone can tell me what, if any, problems I may run into with the tire diameter/transmission/axle gear ratio I'll be using?
Knowing that the E4OD's OD is a 0.712, my tires are 37's(probably closer to 36.5's), and my rear ends gear ratio is 4.88:1 my engine RPM should be around 2050-2075ish at 65mph
at 75mph the engine would be turning at 2360 to 2400 RPM
Does anyone see an issue with cruising down the freeway like that?
Thanks
Thanks
