265/75/16. Vs 235/85/16
cody3700s
Kingsley Michigan
I got myself a 85 250 2wd with a 6.9. Stock tire size is 235/85/16. I have a set of 265/75/16 with about 10% tread wear. I was wondering ifit would hurt to run the 265/75/16 size on my truck.
Thanks,
Cody
sjwelds
Central KS
Should work. Basically the same tire diameter. Should clear steering etc too
Mulochico
Modesto, Ca
Tire height is almost exactly the same. You will get a little more resistance because they are wider.
the tires will fit. they may bow a little with the pickup rims (16x6). on my SRW trucks, I run the van rims(16x7)
keeps things looking stock and I can run a little wider tire (265's)
madpogue
Madison, WI USA
I'm running 265/75s on my '85 (bonehead me, didn't notice that the aftermarket rims I bought were too wide for 235s....); no clearance issues whatsoever, and the overall diameter is within something like 1/10 of an inch. 'Course, mine's 4x4; not sure if clearance is that different.
brb5
