2002 F-350 srw
hardbound
Prince George/Va./us
Looking at truck that has rear end issues. May be a better option to change out rear depending on condition once we determine problem. Anyone know what model years would interchange with this rear.
snicklas
6.0 and Loving It!!
Staff member
Greenfield, Indiana
Should be 99 and up through 04 F-250 and F-350 SWR with a pickup box, not a Cab and Chassis SWR F-350.
The wheel pattern is 8x170mm. I think in 05 when they went to the coil front on the 4x4, they also changed the axle width and wheel size due to larger brakes. The wheel is a 17" rim vs a 16" on the 99-04. You can see the difference in width by looking at the wheel, a 99-04 has a bit of "dish" in the center and the 05+ the wheel has almost no "dish", it is almost even with the outside bead.....
dieselmainiac
