Oookaaay, that was one heck of a birthday party for Our Country- I think my head fell off
But, I'm back at it and while I wait for parts to arrive, I've been going after details.
First thing is trying to dial-in the Trans Fluid Dipstick to read correctly. I purchased a stick online, assuming
the Tube I had was from an Econoline (which I remember pulling it from an early 90's at the Pick-U-Pull,) I put
the two parts together and I got this:
What you're looking at is the long tube inserted into the stub tube (which goes into the E4OD,) and the new
dipstick I got. Note the amount of stick-out of the dipstick...
there is 4-1/2" of stick-out, which seems like too much.
Anybody know or could someone who has their trans apart maybe measure and let me know?
If it is too much sticking out, I can weld a little more to the top end of the long tube (good thing, it will be easier to
access the dipstick handle.)
The C6 had about HALF that much sticking out.
Kinda stuck on this one, can't find any spec or even pics that might help!!!
Borg Warner 1356 Teardown and Rebuild
This topic has been covered pretty well in other forums, BUT there are a few items which have been overlooked
and could make things a little easier for the rebuild.
The BW1356 is part of the planned E4OD build so I want to include it (and also the upcoming cooling system and
electronic control.)
Be sure the Transfer Case gets drained real good, then remove the tailshaft housing:
<edit: Note I did not cover removing the speedo drive gear, it's not that hard really, just slide off the clip ring/band
which is located just ahead/behind the yellow (in this case,) drive gear, then slide the gear further onto the Output Shaft,
where the clip band was, then let a little ball bearing fall out from where the yellow gear originally resided, then slide
the gear off, and also a black rubber spacer.>
Torx bits hold the transfer case together.
It is a good idea to buy a QUALITY Torx Bit set, there are a LOT OF BAD quality tools out there and Torx bits
will bear this out. The bits tend to twist, or yield and get wrecked easily if the bit material is sub-standard.
Go with a major brand name is my advice.
Note the bore in the Transfer Case for the speed sensor AND speedometer cable. (Keeping in mind my 1985
Van has a cable driven speedometer and the newer E4OD uses a speed sensor.
These two parameters are built into one unit:
The cable has a squared end that is inserted into the sensore/drive adapter (red o-ring.)
The two-pin connector is for the VSS (Vehicle Speed Sensor, blue gasket) which in my case connects
directly to the Baumann Controller. The 6.9L idi does not require an engine management parameter.
I had to verify the fitment, since this was a new component to me:
The speedo drive gears are not shown, but were calculated to match the size of the new tires planned later on.
Next, the Output Shaft Circlip is removed,
And again, this is a case where it pays to buy better quality tools. The Circlip has two little holes into which the
pliers get inserted. I had to file the plier tips to fit just right into the little holes. This tool is used more than
once on the Transfer Case.
Carefully the case is split. It is basically glued together using specialty RTV,
(Continued...)
(Continued...)
