Thanks asmith,
Yes, the engine circuit is helpful to get up to temp
on most E4OD's. My E4OD has a
bypass valve which has that
viscosity "sensor" (it's a spring actually) that returns fluid back to the transmission. I am wondering if that is enough
or not to get me up to temp quickly? (in Southern California and Mexico most all of the time.)
See that "lump" at the end of the line? That contains a very sensitive spring, so when the pressure is too high
either from cold/thick liquid or the pressure builds up from a clogged cooling circuit, the fluid will return back to
the sump and fluid supply is maintained. TrackSpeeder pointed this out to me, this was one of the major design
flaws of the E4OD, it serves to warm the fluid AND buy some time if the Cooler and/or Filter are clogged. An E4OD
would starve and burn up quickly. At 45 bucks, it's cheap insurance and makes sense to me.
The Bypass Valve, when combined with a
larger transmission sump, will buy critical time to allow a driver to avoid
a meltdown. The BV also negates any need for the
Engine Radiator's Trans Cooler to try and heat up the transmission.
(Usually when the transmission needs warming up, the engine is ALSO in need of warm up and the engine's cooling
circuit has not cracked open (thermostat) yet.) The Bypass Valve lets the frictions and torque converter heat up
the fluid by not running the Cooling Circuit.
So, the "jury is still out" on this one. I don't think the Ford engineers intended the rad/cooler to warm up the transmission,
or at least not to the degree of the BV. I do know that the Bypass Valve was designed in part for that purpose.
Still, it's got me thinking, I have to flush the engine radiator's Tranny Cooler if I go that route...
The other thing is I have a fan set-up on the extra cooler which is thermostatically controlled and I am trying to
figure out if that is enough by itself, it will be adjusted to around 180 degrees. That should cover me at idle and
setting still for long periods while running.
The big gain by keeping the fluid circuit smaller/simpler is a higher fluid pressure is the result, and that is a very high
priority. Yesterday I figured my (out of tranny) fluid circuit with the Big cooler it has right now to be about 30 feet
when stretched out straight. That's THIRTY feet through a drinking straw, and like my shop compressor, there is
a pressure drop from the compressor to the gun, more so with fluid than air too.
Not arguing with you here, this is what I am debating/facing. A good decision now will make things last longer.
Best regards,
George
