Color might be okay.
Just gotta see it on the truck first.
Sent from my USCC-C6721 using Tapatalk
guys,don't be afraid to just mistakenly leave this thread open so your ladies can find ya some Xmass gift idea's here.night after night leaving these pages open should do the trick.
I haven't decided yet where I'm gonna put my gauges, ideally I want them up on the shelf below the roof, but there's no snowball's chance in hell the coolant gauge capillary tube reaches all the way up there - the oil pressure gauge line I can extend no problem, and the oil temp gauge is electric, but the coolant temp gauge will be a problem... Where did you punch the hole in the firewall for the capillary tube on your green truck, and what grommet did you use to seal it? I figure if I make it pass thru the firewall in the area where the throttle cable goes I'll have around 2ft (out of 6ft total) of tube inside the cab to work with - not a whole lot, but better than just a foot. Where does your mech temp gauge sit in your green truck anyways, got a picture handy?
As for the color, if earthly tones is what you're after then yes, brown will be good, and that's a cool brown you picked - just make sure you see it in person, preferably on a Mini that's not brand new.
You say that, but it was exactly one of them that killed my supposedly "flawless and idiot proof" MD truck - she's actually not only a bleach blonde, but an asian halfbreed too, so worst possible combination if stereotypes are to be believedFORDF250HDXLT said:set right up so even a blonde chick could work it right to death without ever hurting anything lol.
Any plans for turbo in the near future? If no then I got something you may be interested in - power steering filter that when installed looks nearly factory and uses space that is generally worthless for anything else.FORDF250HDXLT said:stay tuned to see what log truck gets next!
yeah,only if the sender is placed in the head @ the over temp light spot.she wont reach the oem temp sender location with the gauge placed up there.So a mechanical temp gauge has long enough capillary tube to reach a pillar pod, that is good to know. Do check where you ran the tube thru the firewall of the green truck tho, if you don't mind.
